Company Logo Shop Now
John Deere's Buff 1k Primer vs a 2K Epoxy Primer
LipRipper3006
05-10-2020 18:53:00
How does John Deere's buff primer compare to a 2 part epoxy primer? If I use the buff primer I would only use it on the case, engine, rear end, wheels, and some other non-visible parts. On the frame, hood, grille, and pedestal I'm going to bodywork and fill primer so I'll need the two-part epoxy so I won't have any lifting issues. Is there any reason to use the buff over the epoxy? Thanks
D-
05-12-2020 17:17:57
 Re: John Deere's Buff 1k Primer vs a 2K Epoxy Primer in reply to LipRipper3006, 05-10-2020 18:53:00
If you are using Deere paint there is no need to use primer on the areas you mention. On some bare areas I spot with Rustoleum rusty metal primer from a rattle can. On sheet metal where you've filled or have some pitting I use urethane primer to hide sanding scratches etc. Then sand it with finer paper. You can paint directly over it.
J.Wondergem
05-12-2020 16:04:59
If it were me, I would try it on a piece of scrap first. I have never shot John Deere paint.
J.Wondergem
05-11-2020 05:09:52
Only if you can't get the top coat on with in the time limit it states on the can, or need to do more prep work before the top coat.
lipripper3006
05-11-2020 15:13:55
 Re: John Deere's Buff 1k Primer vs a 2K Epoxy Primer in reply to J.Wondergem, 05-11-2020 05:09:52
The only reason I would use the buff primer is because I wonít be doing anything other than spraying the primer then topcoating. Not sure about the Deere primer but I use Eastwood 1:1 and itís supposed to be able to topcoat for 5 days but I wait until itís flashed at about 30 mins to topcoat. I didnít know if the Deere paint would have a reaction or not.
Iím sure the two part epoxy will have better adhesion as it is catalyzed so itís resistant to solvents (like gas) compared to the Deere of which I assume is self etching.
Hay maker2
05-11-2020 04:33:26
I have used epoxy paint. I can not tell you if this was epoxy primer or paint...
When I painted my finished coat of green or yellow on it, it would eventually flack off because the epoxy was smooth and the paint would not stick to it.
I do not know if this applies to epoxy primer.
Copyright © 1997-2020 Yesterday's Tractor Co.
