Company Logo Shop Now
1520 Hydraulics Stuttering
2510Paul
05-10-2020 12:52:49
Friend has 1520 with loader. Loader hydraulics stutter up and, as I recall, down also. Bucket works this way as well. What might be causing this? Thanks. Paul.
Tx Jim
05-12-2020 04:26:37
 Re: 1520 Hydraulics Stuttering in reply to 2510Paul, 05-10-2020 12:52:49
Yes check pressure at scv. What type valve controls FEL? I suggest to disconnect & cap the power steering supply line then test hyd operation. Power steering valves have a history of failed o-rings or valve bodies causing hyd problems
Tx Jim
05-10-2020 13:23:37
Easiest & cheapest things to do is change hyd filter then check/clean trans oil sump screen. Also attach hyd gauge to system to check stand-by pressure which should be 2250 psi. What type valve controls loader & how is it attached to tractor hyd system. With 3 pt raised engine running look in hyd filler hole behind seat for moving oil.
2510Paul
05-11-2020 15:34:11
 Re: 1520 Hydraulics Stuttering in reply to Tx Jim, 05-10-2020 13:23:37
Hi TX Jim. Thanks for your response. I assume the 2250 psi should show up when measured at the rear SCV. Correct?
Thanks again.
Paul
Copyright © 1997-2020 Yesterday's Tractor Co.
