Dublinroad
New User
I have the cover and shifter off the transmission of my 51 JD B and it looks like I may have a sticky detent and or spring on the hi lo shaft towards the front of the tractor. The yoke gets sticky and binds some to cause the shifter to not work well in the high range/gears. Shaft looks straight and not bent.
The yoke slides from side to side but is hard to slide off the left detent notch. How do I remove the detent and spring to check and clean or replace it? Does the shaft and yoke need to be removed to get at the detent and spring? thanks
