Company Logo Shop Now
TractorLinks.com
Re: JD 2010 Diesel - What is this switch?
Jim.ME
05-09-2020 14:42:07
The black pull knob on a 2010 diesel is the fuel shut off cable, not a choke. Those did not have the electric solenoid in the injection pumps, so it will stay running once started, even if the tractor looses electrical power. Beware if the fuel shutoff is in the run position and the tractor is left in gear, a bump, kid pushing the clutch and letting it out when it starts rolling, etc. can be enough to start the engine. It was the rule for many with mechanical shutoffs that the injection pump fuel shutoff was to be left in the off position, Parked where the unit couldn't roll (or wheels blocked to prevent rolling), and transmission in neutral. I mention that in case you are not aware of that and if you have kids around. It might be hard to start when you want it to start, but start easily the one wrong time.
The serial number should be on the engine block, right side. You may need that to be sure you get the correct Operators manual, which you should have to go with the service manual.
[/url]
Copyright © 1997-2020 Yesterday's Tractor Co.
