Company Logo Shop Now
TractorLinks.com
JD 300 Backhose Hydraulic Problems
jeremycfrankfort
05-09-2020 08:49:09
Was digging out a stump and lost backhoe function. Then I noticed power steering went away. Now it won't pull itself at all. I went to change both filters today and hardly any fluid poured out. I know it has at least 15 gallons of fluid in the machine. Runs beautiful, just no pressure anywhere.
Tx Jim
05-10-2020 02:56:42
 Re: JD 300 Backhose Hydraulic Problems in reply to jeremycfrankfort, 05-09-2020 08:49:09
Jeremy
You're welcome. I glad it operates better than it did before cleaning screen.
Jim
jeremycfrankfort
05-09-2020 16:50:26
Success!! Thank you very much. The sump screen was packed with dirt and sludge. I had to remove a plug from the opposite side and tap it out. Once I cleaned it and refilled the hydraulic fluid, it works better than it ever has!
jeremycfrankfort
05-09-2020 10:22:03
Okay, I was about to ask where the object in this diagram is located. But since you pointed out the hydraulic filter plumbing, I think I know the spot. I'll go disassemble and be back to you folks shortly.
Tx Jim
05-09-2020 09:07:40
I forgot to state industrial tractors such as your backhoe has hyd filter plumbing attached where plug(item 28) in photo is located.
Tx Jim
05-09-2020 09:04:26
Welcome to YT
Have you checked/cleaned the sump screen(item 30)? Also check to be sure fiter relief valve isn't stuck open(iteems 18-20).
Copyright © 1997-2020 Yesterday's Tractor Co.
