I've got a Deere CT 322 skid steer and the parking breaks will not release now. Ever since we got it the breaks would seem to start dragging now and then while using it. You would have rev it up and move it back and forth a couple of times and it would loosen back up. The joystick levers would also get stiff like there was too much pressure in the hydraulic system. Then a couple days ago it locked up and would not let off. We checked the seat belt switch and the seat switch, they were good. We replaced the solenoid for the parking breaks, did nothing. How ever the breaks did release a little when we repleaced the solenoid, figured it was because some pressure was relieved in the process. Would a bad relief valve cause this? And where are the ports located to check the hydrolic pressure?
Any wisdom would be greatly appreciated. Thanks
