Company Logo Shop Now
TractorLinks.com
Re: 2030 oil cooler hose
Jim.ME
05-08-2020 06:58:36
Cooler mounted on the side of the radiator is the transmission/hydraulic oil cooler. If you have an engine oil cooler it it just a little canister, with two coolant hoses going to it, mounted between the engine oil filter and block. If the filter mounts directly to the block you do not have one, or at least the commonly used one.
You should get a Technical Manual TM 1051 and the Operator's manual, if you do not have them yet. There are a couple different operator's manuals due to a serial number split, so you should have your serial number to get one. Used OEM manuals are available on eBay, and would be better than aftermarket reprints or the I&T manuals in my opinion.
Bird Cupps
05-08-2020 11:01:04
 Re: 2030 oil cooler hose in reply to Jim.ME, 05-08-2020 06:58:36
jim, thank you. Yes, what I'm calling the oil cooler is the hydraulic cooler, as you say. I don't think I have an oil cooler. I did pick up the service manual and the owner's manual. They are helpful, fer sure.
Copyright © 1997-2020 Yesterday's Tractor Co.
