Company Logo Shop Now
TractorLinks.com
Re: 2030 oil cooler hose
Centash
05-08-2020 05:52:49
It's a formed hose for a proper repair. While it's apart, flush the block, check or replace the thermostat and clean the hydraulic cooler rad as well, fan belt tight, engine timing etc.
Ben
Bird Cupps
05-08-2020 06:35:35
 Re: 2030 oil cooler hose in reply to Centash, 05-08-2020 05:52:49
Is the hydraulic cooler what I am calling the oil cooler? The radiator alongside the main radiator?
Can you point me toward some direction on how to flush the block? I was wondering about that, thinking about how anytime you drain the radiator you're actually leaving some amount of coolant in the system. Of course, I've only just figured out how this part of the tractor works.
Centash
05-08-2020 14:20:55
 Re: 2030 oil cooler hose in reply to Bird Cupps, 05-08-2020 06:35:35
With the rad off, flush water with a garden hose through the upper rad hose outlet. Then, reverse it by putting the hose in the lower rad hose outlet. Use lots of water, flush back and forth til the outflow looks clean.
Ben
Copyright © 1997-2020 Yesterday's Tractor Co.
