jimfountain
New User
New to the forum but the 1962 JD 2010 diesel has been in the family since 1966! Anyway, we just use this guy for mowing... 20-30 hours a year. Over the may years the idiot lights went out and we put in aftermarket temp and pressure gauges. Like an idiot I noticed the gauges had failed but didn't worry as I only had an hour or so of mowing.. Then when I broke a fan belt it overheated and cracked a head.
Got it back together now. Stuck on new water temp and oil pressure gauges. Went ahead and had the injection pump rebuilt. Runs better than it has in years... pulls strong and oil pressure is 40 on cold start idle. But after running for a while (water temp 180ish) the oil pressure drops to 20. At idle the oil pressure falls to 5-8. Throttle up to 1950 RPM or so and I get 20 lbs. Next cold start I see 40 lbs at idle again.
Hot idle oil pressure seems low. Is this indeed a problem? If so I wonder if it is a new problem connected to the heat? How much pressure should I have at idle? How to diagnose and fix? Any suggestions?
Jim
Jim
