newgenjdcollector
Couple questions Tim.
First off, on the hydraulic seat actuator (pic below) can the lower cap (that hooks to the large return hose) be unbolted and turned 180 degrees? It would really help me out on this project if the return hose could exit the opposite side.
Next question, I have a good hydraulic pump from a powershift 4620. Is is ok to install that in a syncro range 3020? I didn't know if the 3020's trans pump would supply enough oil or if they were about the same.
