SVcummins
Was the 3010 lp the only tractor to not have big fuel tank ?
The parts book shows a standard seat like this or a deluxe seat like you normally see even for the 20 series
Because it didn't use that much fuel in a day. When they moved to 3020s they burned more fuel to make more hp.
Here's my l.p. 3010. I am about 1 1/2 miles from the gas station so when I need it filled up I just drive it there. We are on natural gas so no propane tank to fill off of.
3010 in SV's photo also appears to have other different options than 2 cyl type seat such as taller gear shift lever,utility type fenders & different type than normal 3 pt lift linkage. I'll bet this 3010 was built for sales in countries other than USA
I have a complete assembly like that with brackets for the row crop tractors. Thought someday I might put together a no option 3010 or 4010. Well I would want pto and hyd's so it would still be usable. Tom
I think all the utilities have the taller gearshift to have clearance beside the steering wheel when shifting into 4-7 and 6-8. The short low position steering makes them different and very hard to get on and off of. I have a 3020 gas utility. Tom
That would be pretty neat to do i Could get by without hydraulics but not the pto wasn?t the 3 point an option to?
(quoted from post at 09:02:15 02/29/20) I think all the utilities have the taller gearshift to have clearance beside the steering wheel when shifting into 4-7 and 6-8. The short low position steering makes them different and very hard to get on and off of. I have a 3020 gas utility. Tom
Good Call
From viewing 3010 PC it appears 3 different shift levers were offered.
The book this picture came from has some less
than book quality machines in it so some of these
things may or may not be correct
(quoted from post at 08:56:36 02/29/20) The book this picture came from has some less
That book is New Genereationof power. Older book but very good before internet. That book alone is the reason for me to get a 4620 powershift with cab and a 2020 row crop like in the book.
