John Deere 5020
SVcummins
With pfwd
Looks good,,if it would have had a shaft driven front end it would have been a real work horse..
That would be something all right. I still want to build one with a double pump out of a big loader but I doubt I?ll ever get the funding put together on that project . Maybe I should start a go fund me account
John Deere pfwd is hydraulic driven but was never factory equipment on a 5020. They came out with the side console 3020 and 4020 and went through the 4640 is the largest one it was available on so you couldn?t get it on a 4840 they weren?t all that swell they worked pretty good to move some or scrape corral or get through a tough spot in a field but it wasn?t like mfwd tractor
They were like comparing too small of cylinder on a loader,,it will go up and down with no weight on it,,but don't work at all when you need it to lift something heavy..low presser/flow was why..
This tractor has a 500 dollars deere 7700 combine rear axle. 4520 and 5020 have same knees diameter. This tractor came from an auction in the USA that machinery Pete attended.
Polk had a 6030 hfwd few years ago.
Do you have it on the tractor ? I seen a John Deere with a mfwd axle one time to it was a new generation tractor not sure the model
That?s why I?ve got this idea of a double pump and make that puppy work like it should . The 6x6 graders have a hydraulic front end on them and those things work
No it's on a shelf in the shop. I drove to northern Minnesota to get it planning to put it on my 4840 but ended up buying an 8300 so never put it on.
