A model 60 s/n6057739, started having trouble getting it started. Worked one day and not the second scenario. Thought it was the starter so took it to a shop, they said the bushings were bad and had let the armature drag against the coils. The shop showed me the evidence of what was happening while I was there. Got that fixed but now when engaging the starter the bendix gear will mesh with the ring gear but won't release or go back home. I've tried adjusting the rod from pedal to switch but when the bendix is stuck in the ring gear you have to pry it back with a screw driver. Only thing I can come up with is the bushing is bad on the crankshaft letting the distance between the flywheel ring gear and starter bendix causing the binding. What else can I try?
