johndeeregreg
if you don't intend to replace the bearings but your there and can measure and adjust end play do you change the end play or just leave it alone? working on 8430 4wd and the counter shaft in the transmission has 0.022 end play, spec is 0.001-0.004. ideally the bearings should be replaced and adjusted but i don't really want to go that deep into it.
i have always felt you shouldn't change the setting on old bearings thinking they are seated into each other and if you change endplay it will make them have to re seat themselves and cause them to go bad quicker. from what i can see of them they appear to be ok yet as in i don't see any pitting or flaking on the rollers or race but i cant see much of it being its still assembled.
