The 520/530 models which followed the 50s were significantly heavier (about 1000 lbs) than the 50. That 1000 lbs was concentrated totally on the rear of the tractor. The basic difference was the 520 having 36" wheels vs the 50 having 38" wheels. The 520 cast iron wheels must have been 500 pounds heavier (each) than the 50 with cast iron wheels? I'm getting this info from Nebraska Test #486 (JD 50) and Test #597 (JD 520). All tests were conducted with cast iron wheels, no cast iron ballast and tests with ballast had about the same amount of liquid, no fenders. Example: Without liquid ballast, the 50 weighed 4855 lbs and the 520 weighed 5809. The static weights showed the front end weight on the tractors to be the same (1280) but the rear weights were about 1000 lbs heavier for the 520. That along with a boost in HP brought about by 75 more rpm and an increase in compression from 6.10:1 to 7.1:1 and using higher octane gas made the difference in test G. Almost 1200 lbs.
