Where-used search on JD parts site
lfnel
At one time I thought I had figured out how to do a where-used search on the "new" JD parts site. Now I can't figure it out again. Help, please!
On the mobile site, there s a green box with a drop down menu that says Search Parts By: Model, Part Number, Documents. Select Part Number, then type your part number in the search box and hit Enter. You should get a list of everywhere that part is used.
(quoted from post at 17:59:21 01/17/20) At one time I thought I had figured out how to do a where-used search on the "new" JD parts site. Now I can't figure it out again. Help, please!
Took me twice to find it back also. Go to..
homepage
parts catalog
then when the parts catalog page comes up it shows 'Search Parts By'. Click the green box that says 'Model' and you will be able to pick a search by 'Part Number'
Thanks, I guess I got there. Problem is that if the part is NLA, then the "where used" data seems to not be there. However the "where used" search worked OK for a very common, currently used oil filter
