Idaho Bigfish
New User
New to the 2940 and have a hydraulic issue. Had a good day to squeeze in some plow work. After an hour or so, the steering got
choppy like the power part would come and go. Then I needed to raise the bucket at the fence and it chattered moving up and down.
When I got to the end of the next row, the rockshaft would barely come up out of the dirt. So I parked it and drained the hyd fluid
to check the sump screen(did not look at the filter). Had some partials but not much. The hyd fluid did have signs of water. Would
the water in the hyd fluid cause this or maybe a recirculating valve stuck open starving the implements of fluid power?
Any tip for checking pump pressure or to isolate the problem?
Bryan
Bryan
