Load shaft shims
37chief
Location
California
What is the clearance between the load shaft bushing, and the lift arm bearing? My manual doesn't mention shims, but I see them for other tractors. I would think they should be fairly snug. Mowing in rough fields I hear the arms bouncing back and forth. any thoughts? Stan
You can get an assortment of sizes from Deere, some times you may need to sand/grind the surface area while the A-frame is down to get rid of the worn depression... do away with all the end play that you can,, too much is why the seals fail too soon.
(quoted from post at 08:08:09 01/14/20) You can get an assortment of sizes from Deere, some times you may need to sand/grind the surface area while the A-frame is down to get rid of the worn depression... .
Tim
When you state "A frame" you must be thinking about rowcrop not utility tractor because as I know you're aware JD utility such as 401B has no "A frame" for 3 pt draft arms to attach to.
The same thing apples to utility tractors if the shaft is not shimmed up tight it will eat the load seals up...
