B John Deere pto increaser help
Eboor1995
I have a 43 B John Deere with a 1 1/8 pto and want to keep that since my no 5 mower uses that size but needed an increser for feed wagon and manure spreader so I bought the one on left first and it bottoms out 1/2 inch before it lines up with hole in pto to put drive pin in so I got the one on right the sleve but can't see how it will latch the implement side pto on without the groves since they have the quick connect. Has anyone used these? Thanks
That wouldn't work. It's the female end on the left one that stops before it goes on tractor enough to line up hole for drive pin.
I hate the one on the right. They will break easily.
Go buy an over running clutch and measure the depth before you buy it.
Richard
https://www.yesterdaystractors.com/C670F_PTO-Overide-Clutch_9653.htm
I'm with D- on this, so cut off the female end(no splines) and put it on. Please tell us why we are wrong.
(quoted from post at 20:28:00 01/12/20) Why don't you shorten the left one?
It appears to me if tractor pto shaft is bottoming out inside adapter in photo one would have to shorten top end for adapter in order for it to fit on tractor pto shaft
