This message is a reply to an archived post by James Howell on September 11, 2016 at 21:46:01.
The original subject was "Re: John Deere 730 Transmission Fluid Drain Plugs".
Hello,
What is the cover located near the oil filter cover and the oil drain plug?
The governor on my 730D failed and spit ball bearings, cotter pin chunks and weight chunks all into the engine case. I drained the oil and got one bearing but I need to locate more of the pieces before I can comfortably put it back together. I want to take that cover off to see if I can find more pieces, but I can't find anything in the manuals that indicate what it actually is.
Thanks!
Hello,
Thanks!
