Robert23239
Replaced the Roassi pump with a standyn And
Been down hill ever since . Replaced pump because it wouldnt
control the speed or idle anymore. Put it at TDC and pump was lined
up before i pulled it . I saw the mark on oil pump gear at 11:00
The new rebuild throttle wired to wide open but i cut right of the box
Deere says i should of cut it after i dropped it in .
The tractor will start and idle fine but has no power .
As you throttle up sounds like something is holding it back.
Is standyn a direct replacement for the Roassi ?
When the V on oil pump gear is at 11:00 :, cyl should be at TDC right
? Timing problem ? The advance got screwed up when i cut the wire
too soon ? Puzzled
too soon ? Puzzled
