This is a 2240 two wheel drive tractor about 40 yrs old?? Anyway I hit something and broke the right brake line. Lost brake steering which is essential for these tractors to turn under loads. I
replaced the brake line and found a bleeder on the top of the axle and started trying to bleed the air. How long should this take? I seemed to get a ton of air and a bit of fluid but I did this for 15
minutes or so in such a way as air could not get sucked back into the bleeder. Petal still super soft. Any thoughts? Don't have a manual for the brake bleeding proceedure so any help would be
good. It looks like the brakes are using hydraulic fluid--dont see a master cylinder like on a car.
Any help would be mucho appreciated!!!
