backyard mechanic
Next project, Slow leak so tried tightening the nut at the pump and
made it worse. Should have left it alone but hate stuff leaking on garage floor.
Removed the line and see a hairline crack at the base of the inverted flare or double flare so might call it, magnifying glass found it.
Would it work if cut this damaged inverted flare off and put
a standard single flare on it ?
