Hi all, new here and I m having an issue. Last winter i put a new ma carb on my 4020 gas and it never ran better. When I was using it it s just quit like someone shut the key off and there it sat until this spring.The only thing I could find was a broken spring that connects the throttle to the govoner under the dash.i finally got it to start again but hardly runs good enough to drive it. I replaced the points, condenser,coil,rotor and battery, even tried to adjust the carb nothing makes a difference. I was planning to put a better starter and electronic ignition in it if I can get it to go again! Ha ha. Anyone ever tried replacing the troublesome. MS carb with a smaller one? I was reading someone put a MM U carb on one with a little mod. I only use it for yard work and snow removal. Any help would be greatly appreciated. Thanks in advance.
