I picked up a used 328 baler earlier this year. It has worked flawlessly for three cuttings and will digest about any amount or condition of hay I feed it to bale. Never a banana bale and the knotter only missed once on one side of a single bale. Unfortunately a 'cheater' bar was left unnoticed in the filed after a repair in the filed during the last hay haul. It must have got picked up when raking the hay. A very distinct clunk and bang that killed the tractor after the takeup picked up the bar and fed it into the bale chamber. The bar actually sheared. I dug out the culprit bar and attempted to finish the last row of baling. Now the baler will catch at normal feed rate. If you go slow and restrict how much goes in the takeup, then it will bale normally. If you go at a normal speed it will bale and eventually just catch and stop. One thing I notice is the flywheel has a tick while spinning free and the drive line is not spinning. Tick Tick as it spins, I don't remember a tick in the flywheel just spinning free when the PTO drive line is not rotating. So the big question is before I tear into it, are there certain parts or known breaking points I should investigate. It looks like the tick is trying to push that arm a little after the gearbox on the flywheel, not sure what you call that arm but it ultimately drives the plunger. Does your 328 have a tick also is it possible I bent something in that gearbox? Why is there not a shear pin?
