I am restoring an H, and I haven't put the final paint on it yet. I have completely reassembled it, and the steering shaft is rubbing 2 rings around the shaft; one where it comes out the hood opening (the hood is below the shaft at the point it is rubbing the shaft) and the other against the exhaust pipe. I have replaced the bushing in the steering column bearing and I had a machinist rebuild the worn steering shaft. While this helped, it is still rubbing.
A John Deere friend suggested I elongate the holes on the exhaust pipe bracket and thus move it over slightly. Any suggestions on the hood? I thought of two ideas:
1. Heat the hood with a torch and bend the opening slightly.
2. Use a die grinder and make the hood slightly thinner where it is rubbing the shaft?
Any suggestions on which one would work better or other ideas are appreciated.
Thank you.
Thank you.
