JD 2440 Oil cooler rubber hose
Good morning guys! Looking to see if anyone can help me find the part number for the rubber hoses that attach to the lines on the oil filter block and go to the hard lines leading to the oil cooler. I am struggling to find them in a parts breakdown.
Thanks!
The reason you can not find them is because the 2440 did not have an engine oil cooler. Someone either put a replacement engine in it or added a cooler off a newer engine. Try looking up a 4030 on JDparts. It shows some different coolers and the part numbers for the elbow hoses you need. Or you could look 219-239 power units. I have a 219 in my 2510 that has the engine oil cooler. Not sure if they are necessary but it certainly would not hurt anything. Tom
(quoted from post at 08:29:39 09/27/19) The reason you can not find them is because the 2440 did not have an engine oil cooler. Someone either put a replacement engine in it or added a cooler off a newer engine. Try looking up a 4030 on JDparts. It shows some different coolers and the part numbers for the elbow hoses you need. Or you could look 219-239 power units. I have a 219 in my 2510 that has the engine oil cooler. Not sure if they are necessary but it certainly would not hurt anything. Tom
I made an assumption and was wrong. The hard lines go to the front of the block and what I would assume is the oil pump? I will get a picture of it and post. It certainly doesn't look like any of the other pictures on another 2440 I have seen. Would the engine serial # be of any help when looking up parts?
Here is the oil filter housing I have.
