I have a hydraulic line that rubbed against the trans cooler housing and has rubbed a leak in the line. One end of the line goes to the main pump underneath the front axle. The only way I can see to take that end lose is to remove the right side rail. Is it safe to remove that side rail without supporting the tractor?
(quoted from post at 11:12:05 10/12/19) I have a hydraulic line that rubbed against the trans cooler housing and has rubbed a leak in the line. One end of the line goes to the main pump underneath the front axle. The only way I can see to take that end lose is to remove the right side rail. Is it safe to remove that side rail without supporting the tractor?
" Is it safe to remove that side rail without supporting the tractor? "
WHY would you want to?
Not real tough to crib up and support it.
I?ve taken em off with no support under the tractor the engine is a structural Block will it hurt it ? It hasn?t mine
If I was removing a side frame on a 4020 I'd block up engine 1st. The only thing holding a 4020 engine to frt support that contains steering motor are the 2 side frames.
