I have a friend that bought a 720 John Deere LP. Someone had been into the engine to retrieve a bolt from the throttle body butterfly. After they put it
together it would pop back through the intake. They let it set for several years before my friend bought it.we found a bent valve and fixed that. Lapped
the valves, replaced intake and exhaust gaskets and two broken bolts. We set the valves and checked the timing. Points set at 0.020. Plugs at 0.030.
Spark at the end of compression stroke on left and right cylinder. The regular will dispense propane vapors in the intake and throttle body. Idle needles
set at 1 1/4 turn. Load is set at 3 3/4 per the manual for Gar and LP John Deere manual. We can Not get a hint of a bark out of it even when we belted it
to a 620 LP. We changed plugs and condenser from the running 620 to the non running 720 LP. The 620 fired up. The 720 still no fire. I have checked
everything and I must be missing something. I have pulled my hair out. I even pulled the spark plugs and poured some gas in the cylinders to just make
it try to run. No Joy I need some ideas. Someone before had the distributor out by two teeth. It is back in time. Any Help would be Appreciated. Thanks
in advance
in advance
