I'm attempting to rebuild the original marvel schebler carburetor on my 1020 right now and have run into a couple issues. The fuel bowl was leaking badly and it
idled badly and was extremely dirty which is the reason for the rebuild. I've rebuilt the carb recently for an 8n and they are fairly similar so I'm confident in
my ability here. When disassembling it last night I found both the idle jet and load jet/nozzle to be severely buggered up and would not unscrew out of the carb
bodies. I soaked them in some PB blaster a little while and tried heating it gently with a small torch but got nowhere. I soaked them some more and will try again
tonight. In the meantime I will need to replace both of these parts. Where can I find them? I haven't called deere yet, but I imagine if they have them they will
be crazy expensive there. Anybody have a good idea to help remove these two from the carb body?
Secondly, the shutoff solenoid was replaced at some point and does not have the adjusting screw on the back like the manual shows. How am I supposed to adjust the
fuel flow with no adjusting needle like the service manual says? Is it just metered correctly with the size of the jet? Would it be better to replace this
solenoid with a manual screw adjusting needle?
Thanks
Thanks
