Joel Sanderson
Anyone know how much pressure the number series has in its hydraulics? (60, 70, 80, 620, 720, etc.) I'll be putting an hydraulic pump on my D, under the mag, and I'm wondering how its pressure will compare to other tractors. I don't suppose it'd be the same basic pump, now would it? I should take a picture of it, but I've gotta go turn some hay. I can tonight if it'd help.
Is there any reason I can't use modern hydraulic oil (whatever that is) with it? My '44 A says 30 w oil, but I want the D to be compatible with the farm's implements that're run by the other tractors.
joel
joel
