Company Logo Shop Now
TractorLinks.com
John Deere 60 gear shifter pulls out of gear
Heavymand
09-20-2019 12:23:19
Hello, I have a John Deere 60 S/N 6012258 with a gear shifter issue. It can be shifted and driven but if you don't pay attention the shifter will work it's way up and pop out of gear. I can pull it straight up and move it freely without it switching any gears. Now I'm assuming that there is a collar or pin or snap ring or something loose or missing. I would love to fix it but I'm a little gun shy when it comes to transmission work. Can anyone tell me what I need to do or if it's an easy fix or if anyone has heard of this before. Thanks
55 50 Ron
09-21-2019 13:34:54
 Re: John Deere 60 gear shifter pulls out of gear in reply to Heavymand, 09-20-2019 12:23:19
Drain lubricant and look for pieces of snap ring in bottom of case while you have the cover off.
Kansas rhody
09-21-2019 08:42:21
Put the tranny in neutral before you remove the quadrant, makes putting back together easier, at least it did on my 50, good luck
Heavymand
09-21-2019 06:20:41
I can handle that. Now I feel a lot better not having to get too far into the tractor thanks for the help.
turklilley
09-20-2019 19:17:12
There should be a snap ring, washer, and spring on the shift rod. Remove 2 bolts under the dash. Remove shift quadrant.
Copyright © 1997-2020 Yesterday's Tractor Co.
