Company Logo Shop Now
TractorLinks.com
Carburetor dltx 71 vs dltx 72
mikewood869
09-11-2019 19:59:30
Are there any differences between dltx 71 or dltx 72 carbs? Power or anything?
Resting Relics 1
09-12-2019 08:36:07
 Re: Carburetor dltx 71 vs dltx 72 in reply to mikewood869, 09-11-2019 19:59:30
Mike, Seems if they put a 72 nozzle in the 71 carb it would work ok. Just my two cents. Good Luck!
John
Pete in MD
09-12-2019 06:16:49
The 71 is for some A, AR & AO straight gas tractors.
The 72 is for some A, AR, AO & 60 (single induction) all-fuel tractors.
The load nozzles are different.
mikewood869
09-12-2019 05:36:50
I got a 71 instead of a 72 in the mail yesterday, so that's why I'm wondering.
RandyB(MI)
09-13-2019 20:50:57
 Re: Carburetor dltx 71 vs dltx 72 in reply to mikewood869, 09-12-2019 05:36:50
The 71 is the better , more refined carb and worth the most $$$ Keep it.
RandyB(MI)
09-12-2019 21:24:04
71 and 72 use same load nozzle , same throttle blade size. No change in power. All pertinent fuel control parts are same. 71 has spring controlled choke and little different pattern to pin port holes in bore wall by throttle blade. You won't notice any diff on tractor. The 71 shuts down tractor when throttle lever all way back whereas 72 does not so requires you to drain carb or just let it run out of fuel to stop...or use a magneto switch. 71 brings more $$$ but only because of public market perception. Same as the # 51 G carb does. If you bought what was represented to you as a 71...then you paid 71 price and make them give you a 71 or adjustment in price.
Pete in MD
09-13-2019 20:23:38
 Re: Carburetor dltx 71 vs dltx 72 in reply to RandyB(MI), 09-12-2019 21:24:04
RandyB(MI),
The 71 and 72 did not use the same nozzle.
According to FSB 182-S (8/1/51) the 71 used load nozzle 47-193 and the 72 used load nozzle 47-310.
RandyB(MI)
09-13-2019 20:47:53
 Re: Carburetor dltx 71 vs dltx 72 in reply to Pete in MD, 09-13-2019 20:23:38
Doesn't matter what they came with back then, there is only one for both now. Pt # R 10116 . No one runs distillate or kero now anyway so a 72 with gas nozzle is a 71. gas nozzle is all you can buy now for the 71 /72. Most are running gas in their all fuel tractors now anyway so I would say it's a non-issue.
Pete in MD
09-13-2019 21:50:45
 Re: Carburetor dltx 71 vs dltx 72 in reply to RandyB(MI), 09-13-2019 20:47:53
I agree Randy. Thought you were talking about when they were new.
buickanddeere
09-12-2019 05:23:13
Roberts Carb used to have an online catalogue and parts book that specified every individual piece .
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
