JD 830 2 cyn power steering pump
wttnlarry
I am replacing the oil seals in the power steering pump on a JD 830 Diesel 2 cylinder. How will I determine if the pump shaft should also be replaced??
If the lip seals have worn grooves in either end of the pump shaft you could probably install Redi-Sleave(s) or try setting the new seals at a slightly different position to avoid the grooves. As a last resort put in a new pump shaft or have the pump shaft built up and then turned down to original diameter.
Redi Sleave
The key slot will most likely be worn. I had a new slot cut in the shaft I had. But it wasn't easy, the shaft is really hard.
