55 50 Ron
I'm not an expert at identifying particular alternators. This is obviously a Delco Remy but which model? It's on a 4020 diesel. Thanks.
When I was a teenager working in an auto parts store, seems like I recall those GM alternators having numbers stamped on the side, usually in that wider smooth area, that identified the alternator and it's output ability.
It's a Delco 10SI.
If you are looking for a generic replacement, GOOGLE "7127 alternator". The suffix numbers that will come up indicate the "clock" position of the terminals.
To add to Bob's comments, here is a link to a website that provides a fair bit of good info. on the Delco 10 & 12 SI alternators: http://www.madelectrical.com/electricaltech/delcoremy.shtml
FWIW, we are running the 94 amp, 12SI on all of our tractors. Napa P/N 213 - 4356. Highest amp. rating in the 10/12 SI frame, reasonably priced, & most importantly, lifetime warranty.
