CRracer712
I noticed towards the front left hand side of oil pan I'm getting some drips. It looks like the oil pan would be easy enough to remove to replace gaskets, is it?
The rubber boots below my brake pedals, one has a nice knick in it at the top. Is this something that's imperative to repair, if so is it relatively easy to replace those rubber boots?
Looks like I've got a bit of a leak around my rear PTO output shaft. There appears to me a seal in direct contact with it. Is this something that can be replaced with much tear down?
Front cylinder injector appears to be leaking a little diesel on the outside. It's got the pencil injectors. I replaced the rubber hoses to return line a few years ago, they still look new. While running, I could see a all pulse of full. Any ideas?
