Well took my head off my dozer again today after some work. I'd say this is why inwas blowing antifreeze out of my radiator a foot in the air. This gasket when I bought it they said is the one I need. Guess it's wrong one. Pics attached. My sleeve top measures 3.50 inches and the new head gasket measured almost 3.70. Where can I get right gasket. The one I bought crossed with john deere new part number.
You don't say what your dozer is but I'm
guessing you have a 202 engine and a 219
gasket.
Your Deere dealer should be able to help.
Just saw your old post. Surely there is a deere ag dealer closer
than that.
R98461 should be right. $81.52
1969 450 straight. I live in Maine. Dealer isnt close to me. I called and they said unavailable.Jim help me out with part number. Just gotta find a link to order it.
John,
Just to clarify for you. The number, behind the oil filter, in your last photo is a casting number. The engine data tag (model and serial numbers) will be riveted or glued on the other side of the transfer pump; if it is still on the engine. It will look similar to the tag you posted of your crawler model/serial number. It should be in the same area as shown in this photo from the web.
Good luck with your gasket. I don't want the dealer name posted, but can you say what town was the dealer you called is located in?
