Finally got it running but not registering any oil pressure. This may be a little long but I want to give the story to this point in case anything may be relevant. Bought it in Feb-March SW Michigan, it wouldn't start but seller claimed he had it running last year. Got it home, carb was full of crud and corrosion, rebuilt it myself (bought the kit with new float and needle screws & drill bits), changed the oil and drained out at least 2 pints of water to start, then heavy sludge and slate gray oil. Decided to drop the pump to get a good cleaning and inspect the drive coupler, twisted off the smaller line that goes from pump to valve train, after locating a used line I began reassembly and had a washer drop out of the filter assembly area that had been above the filter, it was "cupped". I put it back in the way it appeared to have come out, "cup" towards the tractor and installed the filter. Now I got it started but had zero oil pressure so it ran maybe 30-45 seconds and I choked it to kill it. Some inquires about the washer in the filter assembly said that it appeared it had frozen and caused the washer to cup and this may cause a low pressure, anyone back this up? I didn't get this input until after I'd reassembled! What is the proper diagnosis procedure so as not to cause harm to the engine? I pulled the line running to the gauge and blew it out with air, it wasn't plugged. My own thought is to first drop the filter and flatten that washer out, but any input or advise would be greatly appreciated, it's been a long road but I have to admit I was thrilled to hear it run for the brief period it did!! Also when I tried to stall it to kill the engine I had no throttle "response", when moving the lever you can see that it is moving the linkage but there was no effect on the engine rpm's, it was chugging away at a steady pace until I choked it out? Thanks
