ISO JD 5 mower brackets
ad_arms1
New User
Hi Gentlemen,
My first post here and looking for some help.
I'm ISO the bracket that is circled in the picture, its consists on part numbers AZ2967h and Z8312H. I've not had much luck so far in finding them. Hopefully someone here may be able to help out.
Thanks for your time.
Wonder how many never used that ? It must be to help add some strength when you hit something ?
Looks easy enough to make one.
(quoted from post at 21:28:47 08/08/19) Wonder how many never used that ? It must be to help add some strength when you hit something ?
Judging by how hard it has been for me to find one, I'm guessing most where not used and have long since been sent to china.
I currently have the mower mounted and it is very flimsy with the bar raised, I know exactly why Deere offered them.
The updated quick attach setup never used this bracket, however is was designed to be used with the redesigned hitches which are of a much sturdier design than the earlier angle iron hitch.
If I can't find one I'll make one, I'd just like to have original.
Are you only looking for the bracket circled or the 2 step brackets also that mount on the side of the drawbar? Those are the 2 I have.
They mount to the flat bar on the front of the mower. Clean and painted.
