345 lawn tractor
I just need to mow today before going on vacation. I will get the correct oil. Just want to know if I can use it for a temp issue of the transmission being low
From JD web site.
It can gel up,go get what is required,save
time,money,and headaches.after you add other
brand oil you never get it all back out.it turns
to jelly,your friendly john deere dealer will
glady repair it costing you many times what the
required oil costs
I would rather run the hydro a little low than mix the oil in a hydrostatic transmission. How low is it???
Also the oil your talking about is the wrong viscosity for your JD 345. It uses thinner oil.
Your gambling with a high dollar repair ($500+) over waiting to mow your yard. The lawn will not die if it is not mowed for a week.
