Tire ballast - will it hurt to run one with fluid & one
Dearfatbull
New User
4020 with a front end loader. Had old rim/tire with CA in it and the rim finally rusted through. Replaced it.
Hubs did not put fluid in the new tire, and isn t sure if there s fluid in the other tire or not. Will it hurt anything if one tire does have fluid and the other tire does not?
wont hurt a thing. just will spin out before the other tire. on my pulling tractor I have no fluid on one side so I added two extra weights to that side . seams to balance out.
I would not do it,, the balance of the tractor will not be good,,it will give you a stronger chance for it to upset,,this scenario got a young man killed in a roll over a few years ago in my area, he for got about it and had the loaded tire on the down hill side..
On a 4020 with a loader you will need both rear tires filled with fluid plus more weight yet. A 115 blade hanging on the rear is perfect amount extra !
