2010 john deere hyd cover plates
great 2010
New User
I recently purchased a used remote cover plate c13452c when I went to install it I noticed it had only one small O ring location plus the larger O ring and cork seal. My old plate has two small O rings plus the larger one and the cork seal. Are there two styles of remote valves and cover plates for the 2010 ?
(quoted from post at 11:07:30 07/11/19) I recently purchased a used remote cover plate c13452c when I went to install it I noticed it had only one small O ring location plus the larger O ring and cork seal. My old plate has two small O rings plus the larger one and the cork seal. Are there two styles of remote valves and cover plates for the 2010 ?
There were two "power beyond" plates made over the years, C13452C later replaced by C14656.
I'm NOT sure what changes went along with that, but it MAY explain differences you are noting.
Also, does it have a valve for remote couplers under the plate or does it have only a three point hitch, and no remote couplers?
