I was using a bush hog on my 720D for the first since I got it running again after sitting 20 years. In low grass it works good , but as soon as get into heavy tall grass, the pto clutch slips and the pto stops working. I changed the oil and put new 10wt oil and tried adjusting the foot lever thinking that it was not getting engaged completely, but without success. I then openned the adjustment window and turned in the screw all the way as the manual said, but I could not figure out how get the adjusting cam to move to a different notch.
Is there some special thing o way I need to do to get that adjustment cam to move to a new notch to tighten up the clutch? I really don't want to tear that whole clutch apart if all it needs is an adjustment.
