Help identifying old JD
Cagney14320
New User
This crawler came with property. I can't find vin anywhere. Only model serial plate and stamped part. Please help? I need year and model and vin location if possible.
Thanks!
That appears to be the loader ID tag. 810 loader was used on the 1010s and the 820 was on the 2010s. Look for a metal tag riveted to the right side of the engine block or the left side of the bell housing, to ID the crawler. The 2010s used either location, early S/Ns used the block, later ones used the bellhousing.
(quoted from post at 08:21:26 06/18/19) That appears to be the loader ID tag. 810 loader was used on the 1010s and the 820 was on the 2010s. Look for a metal tag riveted to the right side of the engine block or the left side of the bell housing, to ID the crawler. The 2010s used either location, early S/Ns used the block, later ones used the bellhousing.
This photo confirms what you stated.
This is not a guarantee saying this is what your crawler is, but it is some info on what the injection pump was installed on by the parts catalog. The numbers on the injection pump in your photo show up in the 1010 parts catalog as one of the pumps used. It was used on 1010 tractors s/n 17361 (1961) to 31000 (1962).
Yes, I believe the serial number tag was originally on the block, in the area ahead of the oil filter as in the photo you posted.
(quoted from post at 07:47:36 06/18/19) It's been a long time but wouldn't 2010 have a different shifter?
there were a couple different transmission options on them. Mine is a power shift with power reverser
