John Deere model B tractor
Hi, I can sure use some help
I m trying to convert 1944 model B from hand crank to electric start. I changed the flywheel I changed the crank cover but I can t find any starter that will fit this mount. See attached photos
Any ideas?
Thank you
I think you need a flywheel and starter from an early styled tractor. You have an early styled tractor with a late styled flywheel.
A starter for an H is #1109600 and the drive spins from the outside in while a 1107445 drive spins from the inside out on the armature shaft and has much larger windings. Not enough cranking power for an H starter to turn a B over to start. IMO
boaz If you don't care about it being original you can use a gear reduction starter. I think this is the right one. Deleted my bookmarks for the starters. 10 tooth and 40 mm gear. Use them on our pulling tractors. Lynn
(quoted from post at 19:54:18 06/18/19) boaz If you don't care about it being original you can use a gear reduction starter. I think this is the right one. Deleted my bookmarks for the starters. 10 tooth and 40 mm gear. Use them on our pulling tractors. Lynn
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto26831.png">
Thank you all for all the support. I ordered a starter let s see if it s going to work with the flywheel I have. I don t care if it s original Just want it to work. .
Thank you
Bo
I want to thank everybody here for their support, at the end, I had to Mcgiver" it But it works. See photos
My new challenge.. the hydraulic lift is stuck in the up position. I added oil pushed the pedal it went up. And won t come down.
Any ideas what can it be ?
