Monkeymaster
JD 60 sat for 5 years.
Removed the plugs, shot some oil in the cylinders, whirled her over and number 1 cylinder had no compression, number 2 was fine.
Looked in thru the spark plug hole and saw the valve was open.
Whirled engine over watching the valve and the valve did not move in or out.
Do 60's have hydrulic lifters ?
Was wondering if the lifter had bled down and not pumped back up to make the valve move.
Tractor ran when stored, block was drained.
Looking for ideas before I remove the valve cover to see what if anything I can see.
Was thinking maybe a rocker is broke, or bent push rod, ect ?
Thanks in advance.
Thanks in advance.
