blue_tractor_man
My 180 mower is only delivering 6 volts to the starter solenoid when the small wire is hooked up, but 12 volts when you unplug it. I have removed, cleaned, and replaced every connector I can find, and replaced the ignition swith. When you jump from the battery to the solenoid it starts every time. Hook the solenoid wire up again and you get a faint clunk when turning the key.
It seems obvious that there is a dirty connection, green corroded wire, bad solenoid, safety switch, or relay somewhere that I have not found.
Are the safety switches sort of daisy chained, or is there a relay somewhere hidden?
I have an owner's manual and a parts book, but no schematic.
Thanks for any help.
