JD 650 4x4 Tractor Steering Arm
pittpanther
New User
This message is a reply to an archived post by cdhunter on February 14, 2019 at 15:57:13.
The original subject was "JD 650 4x4 Tractor Steering Arm".
How did you manage to get it off. I can't get either part to budge.Thanks
There are (2) dowel pins that can make it difficult to remove the steering arm. I had to use large screw driver and a hammer to separate the steering arm from the steering knuckle. [b:1a8e6b2426]Be careful not to damage the shim[/b:1a8e6b2426]s between the steering arm and the knuckle.
I see the two pins you mentioned. What about the other side of the broken part. I removed the cotter pin and the nut at the base at both places but it still won't budge. Thanks
