Company Logo Shop Now
TractorLinks.com
how to get hydraulic cylinder apart
Ray
05-13-2019 11:15:55
I have a john deere 482C forklift with a lift cylinder that just started leaking out the top. The cylinder is 8 ft tall. I removed the cylinder and layed it across the forks on my shop forklift. I removed the end cap to remove the cylinder rod. I can't get the rod out of the cylinder. When I removed the cap just below the treads is a sleeve of some kind that looks like it is made of brass. I can move the rod back and forth easily, but it won't come out of the cylinder bore. It hits the sleeve on the end and stops. I fastened a chain to the end of the ram, pushed it back and gave it a good jerk. It hits the end sleeve and that's it. There's a weld around the cylinder about 3 inches from the end. I'm wondering if maybe the sleeve is a supposed to move. I have a seal kit ordered. I went to a local JD dealer, but they have never worked on one. The picture the parts guy showed me wasn't much help, but it showed a seal below the sleeve. A repair manual is over 100 bucks and I don't know if it contains anything of use.
Mike(NEOhio)
05-15-2019 15:51:38
 Re: how to get hydraulic cylinder apart in reply to Ray, 05-13-2019 11:15:55
The cylinder rod on the 1207/17s have a snap ring in a groove. You work through the fluid port with a screwdriver to push the ring into a deeper groove.
Russ from MN
05-14-2019 07:11:46
I worked on one someplace where you would tap the sleeve in to expose and internal snap ring in the barrel.
Bob
05-13-2019 11:25:56
Does the cylinder version you have use the retaining bolt, Key #7, and have you removed it?
Ray
05-13-2019 12:59:57
 Re: how to get hydraulic cylinder apart in reply to Bob, 05-13-2019 11:25:56
Yes,it has that bolt and I removed it. My cylinder is a little bit different. The end is flat with two holes to faster it to the boom.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
