Hello, I am new to forums. Im not too good at navigating the forums yet. I am needing to change left and probally right main bearing( The RH doesnt have much play or leaking oil, I changed oil slinger O-ring in LH).
I have a very loose wrist pin in #1 piston/and connector rod bearing on same cylinder.The LH bearing on the shaft is reading 2.750. I am thinking press in new bearing oem bearing if shaft is not undersized.
Is there any forums where I can read on main and rod bearings or any suggestions.Thank you.
